Hi all,
I tried importing a 3d object, and my main model turned like this. Undo, doesn’t work and style is set as default.
MAIN BEDROOM.skp (8.4 MB)
Hi all,
Share the .skp model so the others can see it. There might be faces, groups, or hidden tags.
The component called SKP8818 seems to be the problem. I copied the rest of the objects to a new SketchUp session.
MAIN BEDROOM dr.skp (1.5 MB)
I note you have the camera set to Parallel Projection. That can create issues while you are modeling. Leave the camera set to Perspective for modeling. Save Parallel Projection for scenes.
Where did you import this 3D object from? How did you get it? It’s certainly not usable in your model as it is. This is what that component looks like. Note the dimensions.
I just dragged and dropped the model. I think that’s why it got corrupted.
But from where? What file format is the source?
Yeah. That’s probably the cause.
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
