Hi. Can anyone please elaborate on what exactly happened in this video in the time frame 32:50 to 32:52?
It shows that follow me tool has extruded the entire roof line inwards but when I click on that zigzagged shape and click on follow me tool, only one box is extruded, not the entire roof line.
Are you sure you werenât using the Push/Pull tool instead of the Follow Me tool?
The correct method for using the Follow Me tool would be to select the edges of the roof, get the Follow Me tool and then click on the profile face. You donât select the profile face before selecting Follow Me.
I selected the edges of the roof and then clicked on Follow Me tool in the menu. By this time, when I get the tool, all lines are automatically deselected. Then I click on the profile face/ the zigzagged shape and I see this error notification- âThis does not appear to be a valid pathâ
Iâve been looking at your model and itâs pretty messed up. There are some short edge segments and other issues. If you missed selecting one of the short segments that could generate that message. Youâve got things out of plane and slightly off axis and it would be a good thing if you were using groups in this model.
I agree with previous writers that there are many flaws in the model. But even in this case you can get the expected result. Use the Modifier Key documented in the Instructor:
Do this as shown in the video - preselect the edges, then press the FollowMe tool (the selection will disappear, but you donât have to worry about it), then press and hold Alt key and click on the zigzagged profile. In this case, only one duplicated face on the other side of the roof will need to be deleted.
In a properly designed model, this could be done more easily by highlighting only the lower face of the roof and then Alt + click to achieve the same. You can do this on your model, but then you will need to clean much more.
P.S. The Shift key works just as well as the Alt key.
