No texture
Hi. I have a problem. I imported dwg and I can’t use texture. I see just colors of them, but no texture. I think I do something wrong, maybe in AutoCad? When I draw in Sketch something before import, everything is ok.
You may not have faces that can be textured, or you click in Styles on “Shaded”, instead of “Shaded with Texture”
Or the scale is so large you can’t see the texture.
Without the model we can only guess.
How can I change the scale? I think that’s the problem.
Select all the geometry and use the scale tool to shrink it.
Are you using SU for Schools?
Thank you! I have it now :slight_smile:
