No me inicia seccion
Cuando abro la aplicacion me indica que inicie seccion, pero cuando hago click en el boton me dice inicie seccion desde el navegador pero no sucede nada.
Hi, I’m gonna try (with google trand and my long forgotten rudiments of spanish)
When you say nothing happens when you click the button, does it open your browser, or not even that ?
It seems to happen to people from time to time, you can check this solution
:ceuta_and_melilla:
Hola, lo intentaré (con google trand y mis olvidados rudimentos del español)
Cuando dice que no pasa nada cuando hace clic en el botĂłn, Âżabre su navegador o ni siquiera eso?
Parece que le sucede a la gente de vez en cuando, puedes consultar esta soluciĂłn
Try the instructions in this article:
https://support.sketchup.com/s/article/Log-in-errors
In particular the one about deleting the login_session.dat file.
When I checked the article I found that the link is not working. I have alerted the authorities, hopefully the page will be back later.
The file to delete is in this folder:
~/Library/Application Support/SketchUp 2022/
You can copy that path, and in Finder choose Go to Folder from the Go menu. Paste in the path I gave, and when you go into the folder delete the login_session.dat file, then restart SketchUp.
The Log-in-errors article that is linked has had its information merged into an FAQ article. This is the new link to use:
The browser didn’t open. Sometimes open but not redirection to sketchup web.
Thank you, the issue was resolved with your suggestions
