No longer able to draw diameter dimensions?
Currently testing SketchUp 2024, I seem to be no longer able to draw diameter or radius dimensions, like you could in the older versions. Tried on curves, arcs, circles with faces, circles without faces. Linear dimensions work but hovering with the Dimension Tool on a curve, the curve no longer highlights and therefore no diameter/radius dimension is drawn.
Please have a look at this screencap:
It still works, but you have to hover on a curve/arc segment. The fewer curve/arc segments, the easier it is. If you need a large number of segments, just zoom in (or alternatively, bump up the number of segments after dimensioning).
Thank you! I have 96 segments per 360°, hence me not being able to properly catch a segment. Zooming in helped!
