No Dynamic option on component cursor menu
SU 2025, Looking to create dynamic components in 2025. The component (right-click) cursor menu differs from a 2023 install I have access to. Did something change in SU 2024 and I missed it?
Make sure Dynamic Components is installed and Enabled in Extension Manager.
Illustrating what Box refers to. Dynamic Components will show if you have the extension installed and active.
Thanks, guessing I assumed it was a tool available out of the box
It usually is there by default, something caused it not to be.
Perhaps you didn’t install Sketchup using the preferred Run as Admin method.
Could also be that you install to your K drive, so it may be losing the shipped extensions somehow.
