Help!!
I have been having been working on a badge and it’s been fine the last few days, however, when I opened it up this morning everything I select gets instantly deleted and if I use any other tool like the move tool it deletes the object just by hovering over them.
I am very new to sketchup. so I’m not sure it’s a feature I’ve accidentally pressed or a bug. Resetting the app doesn’t fix the problem.
I’ve checked using a mark pass keyboard test and it says my delete key is fine and no its doesn’t affect any other programs.
Also every so often it fixes itself but then a few minutes later breaks again. I haven’t touched anything in particular that could be causing it to break or fix it.
Windows 10, don’t know and google chrome. Its a laptop I’m using.
I also cant pan with my mouse either, whenever I hit shift it flicks on to the zoom window tool. not sure if that helps
I suppose they might affect it. You could turn them off and see what happens. Clearly something is commandeering key presses. Have you tried a cold reboot of the computer?
