I m was working on my project when my sketchup just freeze & crash.
After restarting SKETCHUP I ve try to re-open the auto-save files i was working on but the file seems corrupt (or broken) now and i m not able to work on it anymore because of a viewing issue : When i get closer to my model he disapear
The file size is 180Mo . Not sure it could come from the size, i’ve got an other 162 mo project who works fine.
I can still work on other project. So i don’t think i ve got issues with my sketchup version.
Same problem with an other computer (a powerfull one …)
Here is what i see when i try to get closer (zoom in). The building is half cut … So i can’t access to the closer objects.
Clipping can be caused by geometry too far from the origin, if you can turn on all layers, hidden geometry and the zoom all. Then select areas outside the require model space and delete. Most likely an imported component will be the cause so right-left crossing selection may catch it.
In my case, it was just a glitch caused by being in parallel projection too long. By switching to different camera mode, the glitch went away.
My model was built fine. But I learned a lesson not to stay in parallel projection mode too long. If you see clipping after being in that mode for a while, just switch camera modes.
