Multiply command name?
I recently designated the X key as a shortcut, forgetting about the multiply command. I can’t find this command in the shortcuts list to switch it back…it is not called multiply. Anyone know what the command is called?
I don’t think you need to switch it back, just remove the x from whichever shortcut you added it.
X is more a function rather than a specific shortcut in this sense.
I use my X key as a shortcut. It just means to use the multiply/array tool you type X after the number you want to multiply.
E.g. 5x
Simple enough fix, thank you!
You’re right, I’m in the habit of entering x5, thank you.
