Is it possible to have lines pointing from text to multiple points in a drawing?
Suppose you are drawing an object that has multiples of a given component and you want to identify these components with the same text label. Because the text floats, it’s not feasible to draw lines as they will not ‘connect’ to the text as it floats. To avoid confusion, it might be best to have a single point at the text end that spits into multiple pointers with arrows at the object end.
I’ve searched and found no hits. Surely I’m not the first to encounter a need to do this …
just draw a second, third, etc… leader line to the same note and hit the space bar, then click out of it. Blank note with line leading to the first note.
When showing the position of several components within a single model, I set the leaders for each different component to a separate color to further help them to see them distinctly.
