Models by Royce
This is almost ready for a prototype build!
In my opinion it could use a Micro Turbo Encabulator like they use on the Starship Enterprise. And possibly some glide wings for jumping.
It looks like you already used a transparent material for the wind reduction unit?
Slap a Flux Capacitor in it and call it good.
Chair A #3.skp (1.2 MB)
Okay, I’m done improvising… for now. :wink:
This is next level! All the best design elements brought together harmoniously.
Japanese Joinery #1.skp (66.4 KB)
I’m modeling based on an article in Fine Woodworking (issue # 292, Dec. 2021) by Emi Shinmura. The difference is that I’m using dimensions that you find here in the USA, so they
are not exact copies of her article. There are more joints and scenes that I’ll post in an edit as I complete them.
Japanese Joinery #4.skp (212.2 KB)
These Screen shots show foundation and post and beam joints that the author said are normally made out of Cypress wood (for rot resistance) in a hot, humid, and earthquake prone environment. Not all of the Japanese names are spelled out for brevity.
Chest of Drawers #2.skp (498.7 KB)
I started out modeling wood drawer guides and ended up with a Chest of Drawers, oh well.
:confused:
Side Table #2.skp (308.3 KB)
This side table was based on an article in Fine Woodworking by Christopher Gochnour (April 2022, Issue #295). There are sure a lot of angles.
Kumiko Tools, Fixtures, and Jigs #2.skp (236.7 KB)
These were based on articles in Fine Woodworking (April 2022; issue # 295) by
Craig Vandall Stevens.
Andon Lamp #1.skp (260.5 KB)
This is based on the same articles as the last post. I had to make the display precision to 1/32" for the kumiko pieces and frame.
Straw Marquetry Table #1.skp (364.0 KB)
The straw veneer in this model is based on the Fine Woodworking article by Gerard Williams.
April 2022 (Issue # 295). He describes the French technique in the article.
Saw Guides #1.skp (132.5 KB)
These are DIY saw guides for 90 degree (finger joint) and dovetail sawing. The advantage of two halves is that they can be clamped in place as shown in the screenshots. They are better made by a tablesaw for precision. These were modeled based on Fine Woodworking input by Christian Becksvoort (issue # 308).
Saw Guides #2.skp (204.4 KB)
After a first failed attempt to make the two halves identical, this screenshot shows how I succeeded in making the first sawguide.
Circular Shop Cabinet #1.skp (691.1 KB)
I intended to model a small cabinet for all the different shop hardware. It has 48 small drawers. As it turned out, it make a table top of sorts.
Saw Holder #1.skp (82.4 KB)
A saw holder for holding saws inside a chest or shelf. Instead of just sawing a kerf, it has
a little dovetail work. In case you didn’t guess, I like dovetails.
Box for Tool Chest #1.skp (104.2 KB)
All the little things that clutter up the top shelf of my tool chest need and organizer, something
like this model.
5-sided Container #1.skp (1.5 MB)
I started making a five-sided plant container to see how many slats I acquired were needed to make it and got carried away… again. :sweat_smile:
Frame and Panel #2.skp (343.6 KB)
So, I inlaid some birds in these frame and panels. Somehow I had a lot of reversed faces and even translucent textures in the bird components that I had to undo. The translucent faces threw me for a loop, because I thought at first they were reversed faces that wouldn’t reverse. Then, I remembered another thread about translucent faces making things look hazy, and sure enough there were lots of translucent faces. (You pick up lots of tidbits by reading forum threads.) :cowboy_hat_face:
Mitered-Dovetailed Box #1.skp (464.6 KB)
I modeled this box, because I wanted to try “Mitered Dovetails”. I also wanted to model some
box hinges from Lee Valley Veritas. I found out that the knife hinges are not meant for boxes. I discovered the Pin Hinges but had to figure out how to use them. They are described as easy to install, because you just drill a 5mm hole for each Hinge leaf. The tricky part for me was how to make the lid so it opens and stops at 90 degrees. Pictures of the hinges from
Lee Valley Veritas are in one screenshot.
Stick Gauge #1.skp (68.3 KB)
Stick gauges transfer actual dimensions accurately (better than rulers or tape measures). They also help verifying projects for square.
Chair #1 - #1.skp (391.4 KB)
I’ve been working on this for a while. Upholstery like the slip seat on this chair has lots of thin parts with plenty of folds. But it helps to model to figure out how much material you need. The
scenes are busy; to read the dimensions you’ll have to open the skp and zoom in to make it out. This chair is not recommended for a large model. It would have to be simplified.
With Offset and Move tools
:wink:
