Model suddenly messed up!
My model suddenly has all its textures messed up. Does anyone have any suggestions as to what I can do to fix this? Thank you in advance for any ideas.
Share the file so we can see exactly what you are working with.
Your profile says you are using “Free Plan”. What version are you really using?
What did you do? Did you import a DWG? It looks like the model or parts of it are very far from the model origin. Share the file to get answers with more than guesses.
I can’t seem to find a sharing link, is there any other way I can share the file?
Thank you for the quick reply.
Apply the 8th icon from the left (Upload) that appears in your window when posting.
Please answer my question regarding which version of SketchUp you are really using. That information will make it possible for us to help you.
It’s the web version.
It’s too large to upload, but if it’s okay to post, here’s the google drive link with the skp file.
I fixed your model. You have the Camera set badly because you’ve select Parallel Projection. set it to Perspective. Also you should fix the incorrect tag usage. ALL edges and faces should be created and remain untagged.
It would also help to purge unused stuff and reduce the size of the excessively large textures.
Here’s also some labels and a component at huge distances from the rest of the model.
You can see one of them way over to the right in this screenshot. Delete those distant things and your model will behave better.
I guess, since you are using the free web version, this is a hobby thing for you so I’ll leave it to you to fix your model. That’s part of the fun, after all.
Thank you. Ill try what you said.
