I cant see texture on my project and when I toggle i cant see anything only small plus signs
i cant see texture on my project and when I toggle i cant see anything only small plus signs fin.skp - Google Drive
Screenshot 2024-01-06 044944
Share the .skp file so we can see what you’ve got set up.
This has nothing to do with textures in your model. The object I show selected includes geometry that makes it incredibly huge.
Screenshot - 1_5_2024 , 3_23_38 PM
That’s more than 16 times the distance between earth and the sun. Hitting Zoom Extents would make it appear that your model has been deleted from the model space.
Delete that object and your problem should clear up.
I also note incorrect tag usage. ALL edges and faces should be created AND remain untagged.
Screenshot - 1_5_2024 , 3_20_25 PM
And you are hoarding a lot of unused stuff.
Screenshot - 1_5_2024 , 3_21_14 PM
Cleaning that up will reduce the file by almost 89%.
will you be able to send me the file? I still cant see the model
Here you go.
By the way, please correct your forum profile. You may be using SketchUp 2022 but that does not identify the operating system nor the graphics card in your computer. We use that information to help you but it doesn’t help when you enter bogus information.
will do thank you so much
