- Same model but when copying to another file, the model can’t be operated as usual, please tell me the reason and how to fix it, thanks a lot!!
and error…
What is the matter ?
It seems you have an active section cut, disactivate it in the model you’re pasting your object in if it what’s troubling you, with the section toolbar
the problem i want to ask is the jagged part on the model makes me not even able to select the model face
Can you share the file?
Long distance from origin.
ohhhh
that’s right, thank you so much!!!
I believe you are talking about the section cut plane itself. Double clicking on it will activate the section cut. You can hide sections in the section toolbar once again
