Model Disappeared as well as the Axis!
True. If you are using it for anything other than hobby use, you need to be using Pro, though. Then you would have LayOut.
Right, I understand. As of now I am just a hobby user.
The problem with text seems to arise if leader text gets dissociated from the entity you attached it to - for example if you delete the object but keep the text. I found that out the hard way with a model that happened to. Zoom extents shrank the model to a dot in the centre of the screen.
I see, I’m really starting to understand it now. Thank you so much!
