Just updated my SketchUp file, and when i went to layout all my scene updated and disappeared in that file. not sure what happened can some explained what happened?
Share the LO file so we can see exactly what you have set up.
Please update your forum profile. It shows you’re still using SU2022 or 2023.
where do i share it?
As you’ve done in the past, upload it to a file sharing service like DropBox and share the link.
have not used Dropbox in years..hope this works
When I opened your file the viewports weren’t blank. They looked like this:
Try closing and opening the file again. Does that change anything.
Since your LO file contains some sensitive information you should probably remove the file from DropBox.
BTW I see incorrect tag usage in the SketchUp model and some unused content to purge.
Close Layout and reopened and it seems to be working. Don’t know what happened, never seen that before. I typically purge my files throughout my working day, i was just starting my day today…
updated…
this is just at the beginning of this project, a lot of back and fourth with the customer at this point.
this will be a big file when done, would be best to put this in to 2 SKU files in stead of one?
Probably not. Best would be to keep the model cleaned up and streamlined as you go.
Thanks again for all your help.
Update,
Can’t see for sure but this issue may not be a Sketchup issue. our IT has been making updates and changes to our computers (and not letting us know). so this may have been the problem.
