I’ve been using Sketchup for many years and have recently encountered a new problem. I bought a new mouse (Logitech g600) which has generally been great. It has 20 buttons that I can map shortcut commands to so that I don’t have to use the keyboard as much.
However, using the center wheel to orbit does not work as it’s supposed to. It always suspends gravity as if I’m hitting the ctrl key at the same time. This is not an issue of the axis settings. The mouse behaves this way in all of my sketchup models. I’ve also tried old mice and they work correctly.
Furthermore, If I use the orbit command I can orbit normally with the left mouse button. I’ve also tried mapping the middle click command to other mouse buttons and that doesn’t work at all.
I’m wondering if anyone else uses this mouse for sketchup and if you’ve run into this issue.
Thanks!
