Does anyone know where the product models are located in the Medeek Ecosystem? I want to add my own light fixtures, electric panels, etc.
Check program files Very wrong.
in the SU plugins folder
Ah, I was thinking of the framing presets and material files located at:
C:\Users\"you"\AppData\Roaming\Medeek\2017\medeek_wall_ext
You’s right. All the electrical fixture folders are at:
C:\Users\"you"\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins\medeek_electrical_ext\library\
OK, So I found the models used, but now I see that there are things beyond the model of the item needed for a project.
Do you have step-by-step instructions to create a new product in Medeek Electric?
This is a standard 200A Electric Panel/Meter and AC Condenser Unit that we use in the Phoenix Metro Area, and I would love to have them available in my drop-down menus in Medeek Electric.
So I’ve enabled additional hardware for some of the menus but not all.
The best resource right now is the tutorial videos:
I need to review these and the various menus and determine what instruction I have provided in this regard.
I also like to provide as much industry standard hardware as I can, let me give this some more thought.
Can you send me these two models, so I can further analyze them.
Thanks.
I’ve emailed you a link to a Google Drive folder with the models in it.
Excellent, I will be looking at these models, thank-you for making them available so quickly.
I’ve contacted Rheem and a few other HVAC manufacturers and inquired about 3D models as well. I’m mostly interested in manufacturers models so that I can obtain more accurate dimensions, from that I like to develop my own simplified low poly models. This pattern has seemed to work well in all of the plugins.
Hello,
Providing a link below to Electric Hot Water Tank for you review and/or of interest.
great feature…
- Leak detection sensor sounds alarm when water is detected
- Optional shut-off valve automatically shuts off incoming cold water when leak is detected
Hope it helps’
Sven
ProLine® Master Connected Electric - Hot Water Canada - A. O. Smith
