Medeek Foundation
To be honest I’ve never actually had to deal with a basement door opening in any of my various projects (design or structural) so now I have a bunch of questions.
Notice that typical prehung door frame is not deep enough to span two 2x4’s and a 1/2" air gap:
So how is this typically framed out and trimmed? Are there special order door frames that are deeper that can better accommodate this situation?
*Note: I have not shown the brickmould that would trim out the exterior of the door and cover the door buck.
Yes, like that, except with such an inswinging door, the frame is flush to the inside to let the door open fully, and then a “jamb extension,” as it were, added as needed to the outside edge of the frame. An outswinging door would be another story.
So something along these lines for an inswinging door (however I have shown the door frame and jamb extension as a single solid for simplicity).
Also note that I have shown the brickmould as 2.25" however 2" is a more common width so there would probably be a 1/4" gap between the brickmould and concrete (caulking).
In simple form, yes. Quite probably, you would just buy the door with a stock frame depth and field apply extension strips hard to the PT 2x creating a step in the profile at that butt joint, and a caulk joint to the concrete makes sense too.
I also just realized that my opening dimension for the concrete is not big enough (actually shown correctly for the door above).
For a 3080 door (36") door the actual concrete opening width would be 36" + 2" + 3" = 41"
The 2" is for the shim spacing and door frame (38", typical RO for a framed opening in a wall).
The additional 3" is for the PT door buck (1.5" x 2).
Does this make sense?
That’s my understanding. Others might have a different opinion. Conceivably, the tolerances of concrete might want even the PT door bucks to be shimmed, so you might make it 42" instead of 41."
On the other hand, I just looked at what I did here in my house, and I put a 36" door in a nominal CMU opening of 40" (which with an added joint should be 40 3/8"). The rough carpentry is all covered with trim, so I can’t check what the PT parts were. I think maybe they were PT 5/4. When working with CMU, you kind of have certain discrete choices for MO.
First look at doors installed within the foundation plugin:
foundation_su98_800
A few more door types:
You never know what you are getting into until you really get into it with this sort of thing. I assumed that I could simply copy my window and door modules from the Wall plugin but after further testing there are some subtle differences between a regular framed wall and a foundation stemwall. Hence some adjustments too the code are necessary and this is taking me a few more days than anticipated.
I think I have most of the door options working now:
foundation_su101_800
Not sure if I have ever see this elaborate of a door put into a basement wall, but it is there if you need it.
WINDOW1
Still a few details to work out with the door and window opening module.
As I am wrapping up the details on the new window and door module of the foundation plugin it occurred to me that it might also be useful to have a basement entrance option:
foundation_su107_800
A whole bunch more parameters with this option (ie. number of steps, landing width and length etc…) but it would actually be quite easy to code.
I would probably have three directional options (Left, Right and Center).
The problem with this option would be much the same as every other option, I need to make it as flexible as possible for it to be useful but not overly complex (too many parameters).
I’m also looking for some plans for this type of entrance to better educate me on what is common practice.
Any thoughts in this regard?
Version 1.8.3 - 03.10.2022
  • Enabled the installation of windows and doors for polyline stemwall openings.
  • Enabled lumber and pressure treated lumber textures in the Materials tab of the Global Settings.
  • Added a door and window opening tool to the Stemwall Opening Toolbar.
  • Animation option added to the General tab of the Global Settings.
This is a fairly substantial upgrade to the foundation plugin. Note that windows and doors can only be installed into “polyline” stemwalls, this new feature does not work with the legacy stemwall tool.
Tutorial 11 - Windows and Doors (13:00 min.)
I’ve been giving the Basement Entrance some more thought and I’ve come up with the following parameters for this option:
1.) Entrance Direction: Left, Right or Center
2.) Stemwall Height
3.) Stemwall Thickness
4.) Footing Width
5.) Footing Depth
6.) Landing Width
7.) Landing Depth
8.) Slab Thickness
9.) No. of Steps
10.) Riser Height
11.) Tread Depth
12.) Tread Overhang
13.) Nosing Radius (Typically 1/2")
Let me know if I am missing anything.
First look at a “Left” basement entrance:
foundation_su108_800
I just need to add in the “Straight” or “Center” option and then I can make this feature live.
Version 1.8.4 - 03.16.2022
  • Enabled entry stairs for polyline stemwall openings: Left, Right and Center.
Note: I did not enable the radius for the nosing on the treads but I think this additional feature or lack thereof is not a major issue since it is purely cosmetic in my opinion. If there is enough additional demand for it I will look into it further.
I also have not added any option for rebar into this concrete sub-assembly. Again, I will address that further if there is additional interest or requests for it.
Version 1.8.5 - 03.20.2022
  • Fixed a bug with windows and doors when a polyline stemwall is in a RIGHT direction/configuration.
  • Added a “TRIAL” licensing notice at SketchUp startup to alert users to activate their license/serial numbers if running in trial mode.
Q: Can you do curved stemwalls?
A: Multi-segment stemwalls are possible with the polyline stemwall tool however there is no function for a true curved stemwall. With enough segments one can approximate a curved wall as shown below:
The same method can be used to create curved SOG foundations, footings etc…
A couple of requests today for a grade beam option/tool:
I think it is probably a good feature to add, with top and bottom bar and stirrups.
Due to our family’s housing situation (and moving) I have had to put this latest development on hold but I will be working on it today and throughout the rest of the week as best I can.
