I have this problem with SU 2017 pro. Every time I make the first component in a model this operation require a huge time. Many minutes!!
Thanks
Obviously it should not take that long…
One thought… when you installed SketchUp did you do it the correct way ?
Close SketchUp.
Find the SketchUp installer’s exe file icon [probably in your Downloads folder].
Select the icon, right-click > context-menu > “Run as administrator”
When prompted choose ‘Repair’…
This should set things up correctly.
It might help your slowness issue…
… or it might be related to recent automatic Windows 10 updates:
thank you but I did it but the broblem still exsist.
The problem is only with a big model. Every time I make the very first component in this model this operation require a very huge time. I would like attach the file in order to let you to check it but the file is big (more than 3072kb) and I cannot upload it here. If I delete a lot of objects and the is small to make components is easy. No other user as such problem with a file?
I had some components with only edges, I changed it adding some surface
too. Also I have purge with a plug in the model. The purge command of SU
didn’t help. Now to create the very fist component I need 2 minutes waiting.
I think is a geometry problem.
thanks
