I am trying to fix a model I downloaded. The problem is that all the line are not on the same plane.
Is there a way to make that happen in SU?
grill.skp (1.4 MB)
Check this thread, especially the last post.
I opened your file in SketchUp Pro. Then I
- selected the top view
- switched the display style to wireframe
- switched to parallel projection
- exported the 2D view as a DWG file
- imported the DWG back into a new SketchUp file
grill2.skp (230.1 KB)
Thanks Anssi - I only have SU Make so I can’t do that.
Easy to fix when everything is flat.
simoncbevans link will take me a while to figure out for the next time.
Another possibility would be a draping (sandbox tools) to a face under your geometry, but there are some problems with your edges that should be resolved before you will be able to get separated faces.
e.g.
vector extrude lines through a plane, then intersect
here’s the plugin:
I’ve had success with this plugin: Extension | SketchUp Extension Warehouse
savior
