Hi there! I have zero expertise with SketchUp plugins and tools, but I need to create a slum context and I’m short on time. I was wondering if there is a plugin available for creating components from an entire selection of objects. In this case, I have these boxes, which are already groups but not components. The plugin I was planning to use was DROPCG to place them into a mesh, but they won’t be dropped if they’re not components with an axis. So, I have to make them all components with an axis one by one, and I think even if I installed Drop CG, it would take me an entire lifetime to use it
any ideas or suggestions will be much appreciated! thanks
Drop selected groups/components onto geometry below.
USAGE:
Select the items to drop, then either:
right-click and select DropGC from the context menu
click on Plugins>DropGC
click on the Smustard Toolbar icon for DropGC
Items will be dropped onto visible geometry directly beneath the origin point. If there is no geometry beneath the item’s origin point, the item will not be affected.
I’ve tried that but it doesn’t work, the only way it works is making them components with axis, do you think it is because i didn’t make the terrain with sandbox tool? (i took the mesh from cadmapper and then i used toposhaper after) or my version of sketchup? i will try with another mesh made with sandbox tool!
