Hi all, sketchup for web user here.
I can’t center my project anymore. The cam is somewhere in space and even if I see my project from very far away, I can not zoom back. Select is also not possible… need your help here.
You need to download and attach your model to a reply here so one of us can check it.
AP.skp (4.4 MB)
here is the model attached, thanks in advance for your help
Here you go, you had 2 components at a long distance from the rest of the model and a stray guideline.
APBox.skp (4.4 MB)
hey, thank you so much … that was a lot of work saved!
still don’t know how it worked out as I tried select all and zoom many times.
Cheers ![]()
The huge section planes are the giveaway that there is something near the edge. See how a left to right selection selects the component but not the section planes.
But then I used ctrl+a to select all and shift with a left to right selection around what should be the model, therefore giving me the 5 things that need deleting. Delete.
Then zoom extents shows the stray guide, delete, Zoom extents again and you have your model back.
This is all posible with the web version, the tools just look a bit different.
By the way, the component off in the distance is a toilet. Specifically this one.
seems the toilet fly away in space while I’ve been trying to return to closer view.
I got it now, thanks, was a good lesson!
