Hello,
I import a logo from Adobe Illustrator, as a DXF that I import into Sketch up 2017,
but I cannot extrude it (push/pull it). Any ideas why, this is really all I need sketch up for is to work with making logos for a 3D printer.
Thank You
Hello,
Thank You
I expect you haven’t any faces to extrude after importing the DXF. Or it’s a group/component and you aren’t opening it for editing. We could tell you exactly without guessing if you shared the SKP file.
2 possible options:
the imported geometry may only be linework. If so, you will want to make surfaces out of the linework. Once surfaces have been created, you can use the push/pull tool to extrude it.
There is a good chance that it has come into SketchUp as a component or group. Either explode the group/component or enter Edit Group/Component mode. This will give you access to the raw geometry.
CD
I tried a test, thinking too that it would be a group, but my Illustrator squiggles came in as lines. In one case I was able to make it be a face by redrawing one of the line segments, but in a more complicated squiggle that didn’t work. Not sure why.
Anyway, assuming it’s not a group, try using the line tool to draw over an existing line.
Thx, How do I make surfaces out of the lines/logo?
Try first redrawing one of the edges (“lines”). If they form a closed loop, SketchUp should create a face.
Anssi
didnt work.
Why don’t you share the SKP file as I asked before? Then we wouldn’t have to keep guessing at why you are having problems. It would save both us and you time.
Dig-Testing.skp (1.2 MB)
here is the SKP file…
thx
You need to open the component for editing before tracing the edges. The stroke of the i and “Leather Co” are components nested inside the larger component, you could explode them.
And there’s no point in keeping the Build Volume component. It just bloats the file.
I thought I did all; that…sorry I am new here
ALthough I have used autocad and 3D studio mAx before I dont get this…any chance you could pint form the steps…thx SO Much!
That was Point Form
When I get home from work I can do that.
Thx Dave
Open the logo component for editing. Explode the nested components shown selected, above.
Thanks Dave,
Fantastic…
Just 1 last question…
Is it not possible to select and extrude (pull push) all of the geometry/letters at once?
Or else enter the actual measurement for each one while extruding?
Regards,
Don Gillard
Triggerfish Design Group
778 . 321 . 8744
designtriggerfish@gmail.com
536 – 2050 Scotia St.
Vancouver, BC V5T 4T1
Triggerfish-orange
Push/Pull only works on one face at a time. I can think of at least one plugin that might do them all at once but I would suggest you get proficient with the native tools first.
Pushpull one, then double click the rest to repeat the same distance.
