Are things working correctly with the current graphics drivers?
As was mentioned, the problem you reported is caused by the graphics drivers. The fix is to find a graphics driver version that doesn’t cause the problem. Often that requires rolling back to a previous version. You could periodically check for new driver updates and install them to see if they work well.
Due to changes in the graphics pipeline with the release of SU2017, diabling Hardware Acceleration is not an option. This option in earlier SketchUp versions dumped rendering duties to the CPU and was useful when the user’s computer had an inadequate graphics card.
Another option you may have is to replace the AMD graphics with a suitable Nvidia GPU. Historically Nvidia graphics have proven to be the best at properly supporting OpenGL.
And as another option, since you are using the Make version, you could install SketchUp 2016 Make instead and turn off Hardware Acceleration in it’s OpenGL Preferences settings.
