The text is blue, which typically means it’s clickable. Click on it.
It refers to thread response #13, in which I asked for a couple of things to determine what the issue is.
If you’re crashing, see above for the LayOut forum link titled “LO 2025 - still crashing with buffer overrun error” thread #17 which gives you the workaround on how to work around this silent crash that only occurs on Windows LayOut 2025. (Details available upon request)
and I already found the download links for sketchup 2024.
what I want is the previous build of sketchup 2025, which is not on that download page. I have projects that were built in 2025 that I now can’t use, and trying to open them in 2024 breaks every single dimention I’ve placed in 2025. Because yes, I’ve tried.
update, someone from ProSupport sent me a download link and I am up and running again.
I had the same problem, views not displaying correctly, warning triangles, constant crashing, and all the styles showing in layout with big black question marks.
Looking at my apps I saw that I had sketchup 2024 installed alongside 2025 (somehow).
Uninstalling sketchup 2024 (but not touching sketchup 2025 or layout 2025 (latest versions) seems to have fixed the problem.
this happened to me too after changing ambient occlusion distance and intensity to a larger value. turns out decreasing back the values of ambient occlusion distance and intensity fixed the blank model. took me a while to figure this was the problem, thats how i ended up looking for the solution here.
I keep on having the same problem, inconstantly (only on 2 layouts files (projects) out of 10 different SU files (projects), and sometimes on small or on big files). Today, I got this after updating my SU file and the only thing modified since the last update just 10’ before (and that worked properly) was the position of a door and the modification of a wall (out of a 350Mo file)
I’ve tried every solutions mentionned above (I have no SU2024 still installed, have alr deselect the “experimental graphic engine”, get back to the “old graphic card” of sketchup…)…
I’ve been having this issue for a while. All vector rendered views kept going blank, and the hybrid views were just left outlined. Then the styles icons showcased the question marks, which I didn’t realise was happening until i found this forum. These whiteouts were mostly unpredictable as it would seem to whiteout randomly, but more consistently with previewing more denser SketchUp files.
I tried rebooting the software, My 2025 version was up to date, relinking the files, deleting all previous versions of layout on my device, disabled the experimental graphics engine, but none worked. My temporary solution was to open the file in a past layout version, updating the reference which brought all the rendered views back. Saved and reopened the same file again in 2025 layout and would turn ambient occlusion back on praying that it didn’t whiteout on me.
But just this morning my 2023 layout had completely locked me out for some reason and came across this forum. Turns out the soloution is: if you get a whiteout, 1) Save and close the document.2)Turn off ambient occlusion. 3) Update link reference. 4) Turn ambient occlusion back on . Not sure how this would effect the styles but this has been working for me
I just had this same issue, Layout 2025, trying to update a design I did in October 2024, after updating the Layout link, all viewports went blank.
I read @steven3 idea and opened Layout 2024 and THANKFULLY all viewports re-appeared, even though it warned me it was a Layout 2025 file (and the .SKP file was also produced in Sketchup 2025).
