Layout viewport doesn't change scale
I want the Scale Drop Down Menu to be locked so that I don’t accidentally write 163/124” of an inch is 1’2”.
I hope now, with my sarcasm, what I said made sense.
I have exactly the same problem on my mac - did you find a solution?
No solution yet; just dealing with it still. With a little bit of “try and try again” I can usually get the scale I want. Would be nice if some of these issues get fixed with updates.
Same here. And same fix - pick a different scale, wait, pick the one you want, move on. It gets the job done… :slight_smile:
This bugged me as well, until I just started typing in that field ( eg 1:50 )
Yes, I have been having the exact same problem working on a Mac. Sometimes the scale change happens and sometimes it doesn’t, even on the same Layout page (with different files inserted.) Typing in the scale ration seems to resolve it. Thank you Mike W!
Hello @Zdeedle @napperkt @dickeyride @MarcE, et al,
This has been discussed in a few other threads, but we have discovered the cause of this issue on mac and have a fix implemented for our next release. See this thread response for more details:
Adam
Hi Adam,
Thanks for the heads up. Just to be clear, when I’ve had this issue it doesn’t matter if the scale I’m trying to switch to is above or below the current scale. It just won’t change the scale on the inserted drawing at all. However, manually inputting the desired ratio does seem to work.
Thanks,
Zak
