When both sending a file or inserting a file in Layout is looks like this with little black boxes??? It never used to in the previous versions. What have I done wrong/differently? It looks just fine in Sketch up and only appears in Layout
thanks
thanks
To me it looks like setting the scene background to something else than pure white (254,254,254,perhaps) might be a workaround as it disables the background transparency that seems to be the problem.
Anssi
Thanks Anssi - I removed the transparent background and it helped me out for now. Still I hope the problem will be solved…
I have understood that this is an acknowledged bug in the Mac version of LayOut so it should be on Trimble’s priority list.
Anssi
Yes, this is a known issue with 2017 on the Mac. Based on our investigation it actually appears to be an OpenGL driver or GPU bug but we are working to address it with a workaround in SketchUp and LayOut.
For those of you who are seeing this problem could you post your system configuration information to this thread? Please open System Information with Apple Menu > About this Mac > System Report. Then in the System Information tool get screen shots of the Hardware Overview, Graphics/Displays, and Software subsections.
Thank you,
Thayer
Hi
This is my configuration ![]()
thanks
Thank you. Your system configuration (specifically the AMD GPU) matches the systems where we’ve seen this issue.
My Mac spec:
Hardware Overview:
Model Name: iMac
Model Identifier: iMac15,1
Processor Name: Intel Core i7
Processor Speed: 4 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 8 MB
Memory: 32 GB
Boot ROM Version: IM151.0207.B07
SMC Version (system): 2.23f11
Serial Number (system): DGKNX07UFY14
Hardware UUID: EBFE02B5-A533-5AD3-B4BE-32C73D8FBCB6
AMD Radeon R9 M295X:
Chipset Model: AMD Radeon R9 M295X
Type: GPU
Bus: PCIe
PCIe Lane Width: x16
VRAM (Total): 4096 MB
Vendor: ATI (0x1002)
Device ID: 0x6938
Revision ID: 0x0000
ROM Revision: 113-C773AA-731
EFI Driver Version: 01.00.731
Metal: Supported
Displays:
iMac:
Display Type: Retina LCD
Resolution: 5120 x 2880 Retina
Retina: Yes
Pixel Depth: 30-Bit Color (ARGB2101010)
Main Display: Yes
Mirror: Off
Online: Yes
Automatically Adjust Brightness: Yes
Built-In: Yes
System Software Overview:
System Version: macOS 10.12.1 (16B2555)
Kernel Version: Darwin 16.1.0
Boot Volume: Macintosh HD
Boot Mode: Normal
Hi folks -
Thanks for continuing to upload your machine info. We’re making a list of specific video cards that exhibit this behavior, and we are working on a fix that’s targeted to these cards specifically. Stay tuned for a possible maintenance release if we can get this cleaned up.
Thanks,
Marc
Hi Marc,
Just checking in to see if you’ve made any progress on this issue.
For others, there is a work-around for presenting (in layout). Create a wall around the model–a background for every view or scene of the model–and the black blotches go away. I create a large cylinder and put the camera inside the cylinder.
Leah
