Layout Query Red Dimensions
Spent time on Sketchup but still have a lot to learn about Layout
For some reason two of my dimensions in layout have comes up in red - see attached. They do not print like that. Probably a simple mistake. Could someone explain what I have done wrong/what it means. Thanks in advance.
That indicates at least one end of the dimension is disconnected from the model. It might be that right clicking on it and choosing Reconnect will fix it. Otherwise you can double click into the dimension and move the red dot to connect again. If the dimension value is correct you could also ignore it because, as you see, the red doesn’t print.
Thanks Dave.
That worked. Have been moving things around. Now I know what it means I can work out how to avoid it.
