See this post:
That indicates at least one end of the dimension is disconnected from the model. It might be that right clicking on it and choosing Reconnect will fix it. Otherwise you can double click into the dimension and move the red dot to connect again. If the dimension value is correct you could also ignore it because, as you see, the red doesn’t print.
