the alert function for dimensions has worked great in the past. Currently almost on cue the dimensions all turn red… One notable mention I had opened an older file and the dimension alarm system worked perfectly. Thankfully it doesn’t print this way but its just frustrating. Thanks in advance for any advice.
See this post:
That indicates at least one end of the dimension is disconnected from the model. It might be that right clicking on it and choosing Reconnect will fix it. Otherwise you can double click into the dimension and move the red dot to connect again. If the dimension value is correct you could also ignore it because, as you see, the red doesn’t print.
Also check this post:
