Layout Impossibly Slow
PowerCADD you can set the tool beforehand (e.g. to have have text after the dimension). You can choose several dimensions and change them at once. In general it is a good example for LayOut as it too is 2d. As a matter of fact, I put the scenes and LayOut and then put them in PowerCADD for the rest. I suspect others use their legacy CAD that way.
Just to add to the evidence on slowness of LO, here’s a drawing I have just been working on. The SU file is just over 8Mb and I am on a fast iMac. I wouldn’t normally expect to see this much beachball of death (the beachball itself doesn’t record but you can see when the image gets updated at the end of the video). Such a basic and simple task. Dear oh dear!
What task? And what is “normallly” referring to?
What I am doing in the video is just moving the edge of the window inwards. That is the “task”.
“Normally”, I would expect to be able to do that on the fly without any noticeable delay. But as you can see if you keep your eye on the tooltip icon, you will see it takes a long time to “release” before anything else can be done.
What I think may have screwed things up is the sanitary ware components. When I first populated the drawing, I was using some high polygon count models which bloated the drawing to about 18Mb. I replaced them with low polycount components and purged the drawing, but the effect of having them there seems to have outlived all the amending. I’m guessing though, based on the fact that I cannot conceive what else would have done it.
@simoncbevans, how about uploading the file so someone on a windows box can verify what you are seeing with that file.
Here you go then.
I have read that LO is especially poor on a Mac but I don’t know if that is true.
Model.layout (6.0 MB)
It takes time to think on both viewports. The lower viewport is slower than the upper but faster than the video above. Turning off auto render seems to speed up the process.
I didn’t think of that, so thanks for the pointer.
Do you agree that there is nothing obvious about the drawing that should give LO such a hard time?
BTW, LO crashed soon afterwards on another drawing so maybe it had just got its knickers in some kind of twist.
That would be one for @DaveR to respond to.
I did find some incorrect tag usuage.
Screenshot - 11_9_2020 , 12_56_27 PM
Zooming is fast, too.
Screenshot 2020-11-09 211303
Screenshot 2020-11-09 211247
Why aren’t you using 2D representation of the furniture Simon?
If I assign the furniture tag to the components and update the model in LO and turn off the furniture tag in LO there is no lag.
I’m very careful about what components I use from the Warehouse and I make sure I can turn them off in LO.
If I need to produce some nice visuals for a client I’ll do it in a dedicated LO file knowing that I might have lag because of components but I’d prefer that to not happen and, as I said, will be very careful about what I use…
That’s helpful @DaveR. It seems to identify the furniture as the problem, even though I used extremely simple low count components.
The reason I didn’t use 2D components in this case is that I wanted to be able to see them in 3D for any internal perspective views (not that I have any set up yet). But it’s not very impressive to be using 3D software and be forced to use 2D components within it because LO can’t handle them (if that is what we are effectively saying)!
Maybe this leads on to another related issue. Surely what everyone wants to be able to do is to recreate a realistic model as closely as possible. It is now very common for manufacturers to produce CAD files of things they sell, usually in DXF/DWG form. If it is possible to import such things into an Autocad drawing without bloating it, it should be possible to do the same in SU. I feel that whilst workarounds are all very well, they are also an admission of inadequacy. That might be fine whilst software remains cheap, but as costs expand, more will be expected of it. In short, does Trimble need to address the issue of importing DWG files and processing them so that they are more usable in SU?
Right on Brother!
Nice workflow…but…
Don’t forget you also need to export a scaled JPG or TIFF so you can do “Hybrid mode” :stuck_out_tongue:
Similar logic that we are asking LayOut to adopt also applies to export of DWGs from SKP:
2d DWG = very quick, but gives you only what’s on screen (unfortunately it also explodes everything which is a real pain and makes this function almost useless)
3d DWG = painfully slow as it tries to capture and vectorise everything, even stuff on hidden layers (so if you have your 3d assets in a layer, you have to delete that layer before exporting DWGs)
I do not have time to read all of the comments on why LO is so unacceptably slow. I have done minimal research on the community pages and have tried some basics like switching to raster and hybrid mode and eliminating large components, still with no real change in slowness.
I have had this trouble for a while now with multiple files and two different computers, both brand new.
Slowness occurs typically when I adjust or create a new viewport. Something as simple as resizing a viewport using the blue handles will take 30 minutes or more. Of course this is completely unacceptable and I will literally have to start using another product if it cannot be resolved.
I have also tried contacting customer support and get this message:
CAPTCHA validation error: unknown CAPTCHA session ID. Contact the site administrator if this problem persists.
So another dead end.
Is there some number I can call or some way to have this matter resolved? If I bought something in a store for $20 I would take it back and ask for it to be replaced but here I am with software that costs a lot more than that and I there seems to be an impenetrable customer service wall.
Any help much appreciated!
for what it’s worth, would you be able to share the LO file so that some of us could take a look at it for you…?
Do they meet the minimum requirements?
Eg. a dedicated graphic card , drivers up-to-date.
Hybrid mode is the slowest of them all, as it combines raster and vector rendering.
Things can also be made a bit faster by setting Display quality to Low (in DocumentSetup>Paper). I always do that, but I also set Output quality to High.
Good advice. I don’t always use High output because the pdf files are so large–which I find strange as other software produces as good or better images with smaller pdf files.
That is common with some other software too. It is perhaps the export libraries used. I have found that using the “Reduce file size”, “Save optimized” or similar function in a PDF editor like Acrobat or PDF Xchange Editor can reduce the size of LayOut-exported PDF files by something up to 90% with no visible quality degradation. In the export settings I always turn off JPG compression as it produces ugly artifacts on the flat colour surfaces and crisp lines that SketchUp produces.
