I’ve been doing some documentation of a fairly large model and I have a couple learnings/observations that, to me, illustrate some of the fundamental issues we are facing with LO performance.
I’m thinking it’s less to do with rendering or processing performance, and more to do with interface design.
I uploaded a little GIF to demonstrate a couple of the actions that work slugglishly.
Example:
- Rendering that legend… a tiny amount of information (it’s a scene within the main SU model, but this scene has nothing visible except 10 rectangles)…still takes some time to render or adjust, even if no model update is required.
- Move+copy: just grabbing hold of it and copying can unreliable and laggy.
- Adding dimensions… It’s just not fluid or reliable, even with Object & grid snapping turned off. My visible content isn’t very complicated, even if the model is fairly large.
During many editing operations, even simple ones, LayOut seems to be processing away furiously. One has to proceed very slowly and carefully, or risk making mistakes, because the key presses and mouseclicks seem to be delayed and become increasingly innacurate when we try to work with any speed. (The worst example of all of these innaccuracies - or “glitches” - is when the scrollwheel randomly becomes a “move” tool and ends up shifting a LO viewport vertically on the page. Not good!).
Not helping this process is the fact that some of the actions we repeat a lot are made slower due to the interface design.
Editing a dimension:
- It takes 1 click to Select the dimension.
- Double click to open it for editng.
- Double click again to open the text element.
- Click to position the cursor.
- (make text edit using keyboard)
- Click to commit the change.
- Click again to close the dimension.
That’s 8 clicks. By comparison, in Adobe Illustrator the very same action takes just one click.
Text Style Palette:
I’ve found signficant speed and useability improvements by just shifting the Text Palette to the top of the toolbar stack (so that it doess’t re-arrange the entire stack each time), and further improvements by hiding the Font list (squeezing the editor palette so the font list doenst appear, except for the current font).
Default:
Massively Improved speed:
Colors Palette:
The entire color editor being visible all the time seems to be totally unnecessary. Maybe it could simply pop or slide out when we want to edit a custom color, instead of being a full-time, detailed menu??
( by the way, can we just get a Swatches Palette that actually works, ie when a saved swatch is edited, this would alter the color to all instances its applied to? And can we get 3+ rows if we extend the window further? right now it just makes more empty space).
“Palettes” instead of “Editors”
Perhaps one key to speeding up the interface could be to limit the initial options for editing detailed settings for colour, font, thickness, scale.
Professional users seldom need to select from every possible combination of settings for dimensions, annotations, etc. Instead, what we prefer is having quick access to a handful of pre-set options (that we customise as part of our templates). I think this will also lead to better professionalism and consistency in our drawings; I do see a lot of LO plans where the colors vary slightly within a drawing, and the fonts are slightly different sizes. I certainly don’t need to load 200 Windows Fonts that I never intend to use in LO.
I’ve seem SU+LO users achieve similar functionality by having a number of styled objects saved within the non-printable area of their page, in a template (or as a scrap book), then use the eyedropper+bucket to apply them to the model. …But that workaround doesn’t help with the issue of LO wanting to load all of the styles each time we make an edit to anything.
Drafting Mode:
I’m not sure how much of the above editing functions are present so that LayOut can be used for making “scale drawings” . If that’s the case then maybe there need to be a “drafting mode” with a specific toolbar and some more editing and common CAD functions).
