I’m working on the Layout 2026 (latest update from Trimble), and since the previous update of the 2026 version I couldn’t export in PDF properly.
The viewports got all messed up and distorted. At first I thought it was a problem with the sketchup file, then I copied all the project to a new file. But nothing changed.
Then I noticed the “warning Exclamation Sign” appeared in the Layout, as if it couldn’t sync properly with the sketch up file.
At last I tried exporting in JPEG and it worked perfectly.
I downloaded the PDF24 and printed which worked out as well (although with low quality).
Since the archive was too big, I was working on a copy to send here, and now I got to export the pdf directly from the layout perfectly
I don’t know what could have happened… since the file is big it was syncing all this time? hence the warning symbol?
Mijn collega en ik hebben hetzelfde probleem met het maken van PDF’s. Het ligt niet aan de bestanden, het is bij alle tekeningen. Soms gaan de eerste 2 pdf’s goed en daarna lukt het niet meer. Soms gaat de eerste al fout. Als we de tekening dan openen in Layout 2025 is er geen probleem. Iemand een idee wat we daaraan kunnen doen?
