Layout doesnt do anything. it doesnt change scale it doesnt change when i update the sketchup model
so layout doesnt update anymore even though i update the scenes and save the file. i cant change scale or render style. it just doesnt respond on changes.
Share the the LO and SU files so we can see what you’ve got. I expect there’s a logical explanation but it could be one of several different things.
What operating system? 2026 is not the answer to that question in your forum profile.
microsoft windows, this morning everything worked so its weird that it doesnt want to update anymore even when the file is only a rectangle (wanted to test if the file was to big or something)
Put the Windows version in your forum profile.
Again, share the files. We can’t tell anything useful from your screenshot. Presumably your files are larger than 16 Mb so upload them to DropBox and share the link.
layout test.skp (126.1 KB) its just a square to try out.
You have to share the LayOut file too. I don’t have any trouble with your SketchUp file when I insert it into LayOut. Everything works as expected.
viewport
layout test rectangle.layout (133.4 KB)
In the SketchUp Model panel you have Auto Render turned off so the viewport won’t update until you click the Render button. Turn on Auto render by ticking the box.
Compare the difference in the SketchUp Model panel in my GIF with the one in your video.
That was indeed the problem! everything works back at the moment. big thank you for helping me out!
