Hi, using LayOut 2023 and cannot seam to start the program due to bug-report on startup containing the files: tmp#3D1.net64dmp and B5MH3L71.xml both in Path C:\Users/job/AppData\Local\Temp (which doesn’t exist by the way).
Tried to un-/reinstall multiple times. Please help
if that does not work it might be the LO is using an old .plo file if the previous build directory was copied into your most recent build. The .plo files should be deleted and then relaunch LayOut.
I’m currently having this same issue and tried the last suggestion of deleting the .plo file. This didn’t work. Have already removed and reinstalled the 2022 version and prefer to stay on 2022 for now. Any thoughts?
So I uninstalled once again, went to appdata both local and roaming and simply removed everything related to 2022. This worked, but now I’ll have to go through and add back all materials, components, extensions, etc. Wish there would have been a cleaner fix without all the additional work, but it is what it is. Thanks for the recommendation to download running as admin.
