Layout closes unexpectedly
Hello,
Layout keeps shutting down today. Most of the time there is no bugsplat. The last time I got the Crash # 16150.
The file isn’t large and I have max 4 viewports open at a time on each page. I have tried switching between vector and raster for the view ports but it still closes unexpectedly.
My immediate guess would be the PC/graphics card but I am no expert.
thanks
crash 12-07-24.pdf (36.9 KB)
this just happened. Layout crashed while changing from Raster to Vector then Sketchup crashed. I cannot use these files for more than a few minutes
Might be worth reading about that message. A Google search turned up this.
Thank you DaveR, I have had a look at the link but nothing jumps out as the reason for my troubles today.
In the meantime I noticed one single viewport was a problem with Layout crashing only when I switched between vector and raster on that viewport. I deleted it and am tentatively trying to continue working.
Interesting. I wonder what the deal is with that viewport and how it would take both LO and SU down. Well, maybe it’s sorted now for you.
Fingers crossed
Well that didn’t last long. Neither SU or LO will stay up for more than one mouse click on these files. I am going to have to start a fresh to try to get some work done today. Very frustrating. :frowning_with_open_mouth:
Share the LO file with us so we can try it on a different machine to see if we get the same result or not.
File is too big to upload so here’s a wetransfer link:
I’ve got the file but since it contains client info you might want to remove it from We Transfer now.
Which viewport did you think was the culprit?
thanks, link removed.
Page 03 RHS View
Hmmm … I got a silent crash of LayOut as well as SketchUp after opening your SketchUp file. Time to try to dig into the SketchUp model a bit. I do notice a couple of things already that aren’t good. A key one is that you have no scenes and you’re using the Last saved SketchUp view in LayOut for all of the viewports. This is definitely not a wise thing to do unless this is a one-off document you’ll never need to go back to. You really should be creating scenes for the different views of your model.
In the SketchUp model I found some incorrect tag usage.
Screenshot - 7_12_2024 , 7_33_29 AM
And some unused stuff to purge.
Screenshot - 7_12_2024 , 7_33_49 AM
There’s a tag for “Image” in your model but that tag got purged. What was the image that had that tag?
More digging. Hang tight.
Thanks you DaveR. I have never known about scenes so I’ll def look into that. Tags are new to me also. I have to admit that I don’t know why there are incorrect tags usage.
I wonder if it has anything to do with that image. After cleaning up the .skp file I was able to relink it to the LayOut file and both SU and LO have been behaving themselves. I’ll send you the file in a PM shortly.
As for the viewport thing, here’s an illustration of one of the problems you can have but not using scenes, and modifying the Camera in LayOut. First, your viewport as you set it up.
After the camera was reset.
You should probably take some time to go through the tutorials at learn.sketchup.com
Scenes are important because they establish camera positions and other properties which then become sort of fixed views of the model. This makes what you do in LayOut stable. There are other benefits, too.
As for tags, all edges and faces should be created AND REMAIN untagged. Only groups and components should be given tags. Tagging geometry (edges and faces) just leads to errors and problems.
Look for a PM in a few minutes.
Thank you DaveR
