Layout 27.0.264 DWG Export Issues Workaround
Continuing the discussion from Layout 26.2 dwg export issues:
Just did an experiment because the new version of Layout is still not exporting a DWG file that is usable in our workflow pipeline.
The last version to “work” is 25.0.575 so I’ve been using it while using the newer Sketchup version for modeling. I say “work”, because there are still quirks of the export that I have to adjust after the fact, but I’ve created macros and can easily manage the output.
The workaround if anyone else is interested and wants to take advantage of the new Fills in Sketchup 27 is to have both versions installed.
Open up Layout 27 and do whatever you need to do in there. Save it out.
Open Layout 25 and use that export engine.
Bugs…
Styles may break if they are changed from the default scene style so check those. You can select a different one and then select the one you want to effectively reset the style.
If you update or manipulate a viewport in Layout 25 you will lose any Fills. (Resizing or changing visible tags, etc.) Either go back to Layout 27, update the model, resave, open in Layout 25, then export.
While the new Fills are greats, Fills are not really AutoCAD fills yet. They are linework so don’t expect to be able to manipulate them in AutoCAD. This has always been an issue with Fills unless you use specific ones buts that’s a different topic. Even when exporting from Layout 27 you still don’t get actual autocad fills.
