Layout crashes when exporting as dwg
Layout consistently crashes when trying to export the attached file as dwg. Options - Pages: All, Format: AutoCad 2018, Layers: no options checked, Other: Ignore Fills and Export all to Model Space are checked. Tried ungrouping most grouped objects as that seem to be a fix in the past. dwg exporting has never been Layout’s strong suit IMO but previous version seemed to work fine.
20260615 Top Drawings.layout (383.4 KB)
It crashes for me as well.
@trent I created LO-17289 for this.
Thanks all, we will look into this.
So, Trent…any insight? I’ve got the same problem, swapping out every variable. Layout 2025 did the exact same thing, except I found a workaround by unselecting the “export for SketchUP” on the options window. Layout 2026 doesn’t provide that check box anymore, so I’m really up a creek until this gets fixed. This is the kind of problem that makes it hard to advocate for others to adopt SketchUp. I don’t even know what I’m supposed to do until this gets solved. I need to send DWG format files to my consultant engineers.
Can you open the file with LO 2025 and use the old solution?
Hi @DMK and @labfixtures,
It looks like we have found the issue and a fix will be included in the next release. Unfortunately we are not allowed to disclose how soon that may be.
Adam
