Hello,
I am trying to export a Layout (2022) file (466MB) to .dwg (Autocad 2010). I get the message “Export Failed!” Second time I try it Layout crashes and closes. I tried to export 1 page at a time, same result. I tried to export to a newer AutoCAD format like 2018, still crashes. I tried .dxf format, same result. Any suggestions?!?
Thanks
It’s an enormous file. What rendering method do your SketchUp viewports use?
Thank you for the reply. We found out that we only have to check “Export as native dwg and dxf” Only choosing this option solved the problem. However, layout to CAD problems still haunt us very much.
