Layout 2025 display issue on text
I solved my issue, but I wonder if anyone has found the same problem. I was dropping switch symbols from my Layout Scrapbook created in Layout 2024, and while they appear correctly on the screen, the export shows the symbol clipped or partially covered by white. The text used in the symbol must be close together,so the text boxes overlap. As it turns out, that is because the text is in a bound box. Changing the text to unbound solves the issue. Does anyone have this issue?
Layout Unbound issue.pdf (26.8 KB)
