Lagging while using tools to navigate inside the model
there is lagging and the model cuts out temporarily then returns in response to the tools such as move tool, orbit tool, pan tools. The graphics card is updated
What is the size of the file and what is the edge count? Is your profile up to date?
Could you share the model (via Google Drive or WeTransfer)? I can take a quick look to see where the issue is coming from.
13 million edges is a very obese file, no wonder it is lagging. What is the disk size?
The file is 460 MB, but I’ve used files close to 1 TB on another Dell computer, and works fine. I know the maximum recommended from Sketchup is 300 MB skp file, but I’ve operated bigger files with Asus and Dell with 32 GB Ram, and Processors on both laptops were high as as well. And worked fine, Both graphics cards are 8 GB . I’ve updated them on Nvidia website under “Studio” option.
thanks, I’ll use dropbox or google to transmit the model, as mentioned, there were other files I’ve been using with close to 1TB and worked and responded fine, that was used by,Dell and an expensive gaming computer designed for large loads like in Sketchup. I’ll transmit a file to check
the hard drive 1.8 TB possible, and 1.2 of free space unused
I recently updated to Sketchup 2027,
Please update your forum profile.
Based on other models you’ve shared I expect this one could stand to be cleaned up and put on a diet. It’ll help if you share the file.
(post deleted by author)
Thanks, I just transmitted two skp files. One has only 415 MBs and the second file is 1.15 TB. Its a lot of file space, but I’m using a high scaled gamming computer. I think the problem is the excessive edges on the file with 415 MB which lags a lot, but on the 1.15 TB file that seems to respond okay, but has much fewer edges. But I thought edges doesn’t impact performance assuming the both files carry the same amount of file space e.g.,
I wonder where you got that idea.
Working on the smaller file at the moment. I’ve found your typical incorrect tag usage, file bloat from multiple copies of textures, and other things. Edge count is huge. We’ll see what else. I’m not going to bother with the other file at least until I’ve finished with this one.
It’s not 1.15 TB. It’s 1.15 GB. Still morbidly obese for a SketchUp model file.
I just noticed the mistaken TB instead of GB , thanks
I checked your file. Visually the model looks fine, so the lag is mainly coming from three things inside:
  1. Too many duplicate groups: There are around 31,685 duplicate groups (Group14560#2, etc.) along with 47,600+ component instances. Since they are groups and not components, SketchUp has to load them separately while orbiting. Converting repeated groups into components will help a lot.
  2. Heavy texture memory (~1.18 GB): Even though the file is 411 MB, it has 714 unique textures taking up 1,182 MB in memory (including a 13 MB .tif file and many ~4.8 MB PNG building textures). Compressing or resizing those textures will reduce the viewport cut-outs.
  3. Cleanup & active tags: There were also ~25,000 loose edges and 4,359 unused definitions sitting in the file. Keeping heavy tags like PM - Trees and PM - Buildings turned off while working will make navigation much smoother.
The project is using a lot of file space, and some files tend to be large. So I’m dividing files into many separate small files and keeping them lighter.
Since @N1LESH is looking at your files, I’ll quit. No point in both of us spending time on them.
Please update your forum profile. It says you’re still using SketchUp 2023.
Thanks for checking this with the 'session report. I currently use “Material Resizer” ext, and does reduces alot of textures excess without compromising the texture quality. I’ll try Turning off some of the tags in building and tree while the file is running, to find if that improves response from the tools.
I was just in the profile in my Trimble account, as you suggested, and updated other items, but overlooked the year, I’ll check it again, thanks
No matter how powerful your machine is, there are certain conditions that even the most robust hardware cannot overcome.
Your shared files utilize display settings (styles) that can pose a challenge even for the most powerful systems.
I recommend that you study “Optimized Modeling Techniques,” paying particular attention to the section on “Speeding Up Rendering with Fast Styles.”
I recommend to create a “working scene” that applies the aforementioned techniques… use that for change the model, and the rest for presenting.
In my experience, disabling edge profiles and textures makes a significant difference on its own for models like these.
