I’m trying to join 2x2x1/8 tubing at odd angles for bracing.
I have tried several things. Is there an easy way?
If it was a solid rather than a tube how would I do it? I could quit using hollow structures if a solid would work better.
Thanks in advance
Don
You don’t really need to draw extra geometry if you are willing to erase some leftovers . The 90 degrees is just for the sake of the procedure- it can be done with the scale from the outside.
And without using the Solid tools- one of the ways. Small mistake when I selected the opposite face- it still worked because I intersected with model and not with selection. I am copying the faces inside the group because sometimes the intersection won’t recognize the fighting faces.
