I have read some other posts about this and attempted to fix.
The problem I am having is my lines look fine in SketchUp, when I send to Layout they are jagged. I can change to vector and the lines become straight. However one scene does not change and causes Layout to crash… it spends a lot of time thinking and then if I click anywhere on the page Layout changes to “not responding”, all I can do is close the program.
How else could I attempt to fix this and/or why does Layout keep crashing? Thanks
I have for the moment given up using Vector or Hybrid rendering, except when especially needing it (for example for export to DWG). I set my Export resolution to High and Display resolution to Low. Your image looks like you are using the default Medium or Low.
On a Mac, it is all in Doc Setup>Paper it seems. I had mine set at Medium in both cases. Changing the display to Low doesn’t immediately make any difference but is that because my viewports are rendered Hybrid?
