Layout woes
Is there anyway to make my lines less jaggedy in layout without changing out of Raster? Working with Hybrid or Vector is sheer torture.
You can change the display and/or the output resolution to high in the Document Setup rendering settings.
Well I’ll be damned!
Thank you!!!
Note to anyone with the same problem, do not change the display resolution, only the OUTPUT resolution.
Changing the display causes the same problem, it just circles and takes forever, I had to shut it down.
The Output takes a little longer to convert to PDF, but not too bad, and it worked!
So appreciate your help!
You made my day.
