I am very new to SketchUp. All of my Tabs seem to have disappeared. How can I get them back.
Did you lose your Tag Panels, or have the tags on your geometry been lost?
I am using SU2022 and some of my Tag Panels were lost. Also when starting LO2022 I was informed Trimble is experiencing technical difficulties and I should Sign Out and Sign In again. Rather I just shut SU and LO down and quit for the day.
Now Five minutes later it asked me to sign in again.
Sign In worked and all appears to have returned to normal.
I am not sure. All the tags in “Tags” window are missing. But when I click on a component to assign a tag, they are all there.
Try closing SketchUp and reopening it.
Your profile says you are using SketchUp Pro but which version?
Share the SketchUp model file so we can see what you are working with.
this is the french tag panel, on mac, but it’s the same on a PC
Any chance you have typed something, even just a space, by accident on the search bar ?
here, same file, one space shows me some tags in bold, two spaces shows me empty. and since space is the shortcut to the select tool, it can happen by accident (It has, to me, several times). If you accidentally select your tag panel by clicking on the search bar then press space to to to select tool, bam, search activated
My thanks to all of you! Simply shutting down and re-opening did the trick. I was reluctant to doing that for fear of permanently losing the data. Thanks again.
