I have just installed the screen mirroring app Duet so i can use my iPad as a second monitor. When i try to open Sketchup 2018 Pro, it crashes. I see that there was some discussion regarding this last year but can’t find whether there was a resolution to the problem??
Please help Sketchup team. I would hate to not be able to use the Duet app for monitor extension.
Thanks Anssi. Am i then to assume that this is a Duet issue to deal with or can i ask the Sketchup team to try to create a work around (i am sure they are busy or anything )
Considering that SketchUp has always required graphics cards/drivers to support OpenGL, it’d be pretty silly to expect they are going to make a change in that for you.
Thanks DaveR. I am not technically savy when it comes to computers so done know all that stuff. I have sent Duet a query so lets see what they come back with I will return with their awnser if you are interested.
Currently Duet won’t get past the launching screen on my iPad, so I can’t test the problem. But, I notice that in the settings menu there is a Graphics card option that you can use to set whether it’s using discreet or integrated graphics. Could be worth trying the other one.
As the iPad is connected over USB, and not a display port or Thunderbolt, I’ve assumed that it’s doing a screen sharing thing, it isn’t directly driving the iPad screen. So maybe OpenGL apps should work without crashing.
Well, I meant > OpenGL 2.0. I have to keep 2016 for testing under Windows (in Parallels) because that only does OpenGL 2.0. I doubt many Macs are below 3.3:
Thanks for the help and the comments. Duet has responded to me with the fact that they are dealing with the issue and the next update will fix the problem. There predicted release of the update is the end of March.
