Hello!
Somehow the plugin “Soap Skin & Bubble” is not working on Sketchup 2021? is it something related to a new update?
Thank you!
Hello!
Thank you!
Do you know how to use it? How exactly does it not work?
(most recent versions SU2021 and SSB)
Yes I know how to use it. I just need to uninstall it and install it again I think. Thanks though.
I’m also having issues with it on 2021. The initial skinning works, but trying to change pressure causes it to hang. Eventually my screen turns white and I have to kill off Sketchup.
Anybody knows if updated version is already out? I remember it is scheduled to expire 2021 April. Thanks!
Has anybody found a solution to this problem? I’m having the same problem in SU 2021. The soap bubble creates fine, but trying to add pressures causes SU to freeze and I have to kill the program.
Usually pilot error. Can you show us what you are doing, or attach the model.
It’s working fine for me in SU2021.
I had this issue before but now it’s working fine on SU21. Try to uninstall it and install it again. Make sure when you create the surface to click on :
It should work fine.
I ended up getting it to work by reinstalling it. Though I didn’t get errors the first time around, something obviously ‘broke’. A second install seemed to do the trick and I now can inflate/deflate.
Good luck!
Awesome, that’s simple enough! Thank you for replying!
Hi I had the same problem. Put style settings to shaded and not shaded with textures helps. When I have many forms to produce with soap skin I sometimes even copy them to a new skecthUp document and copy paste them back once ready.
