Hello!
I’m getting an error message every time I open up SU '21. I know that it’s just because some stray files found their way into the Extensions folder. I’m too lazy to clean out the files, is there a way to hide the error message?
Side note: whenever I use the Bubble tool (soap skin) SU (21) crashes. Even on a brand new model, even when I’ve just opened up my computer after days of not using it.
It says “not responding”. I left it while I went out, came back hours later and it was exactly as I’d left it.
That’s not crashing. That’s telling you that SketchUp is busy doing something and won’t respond to further input until it’s completed its current task. What is it you’re trying to do with the extension?
Of course it will. If you don’t want it to come back every time you start SU, fix the load errors. Clicking OK on startup is the tradeoff for being too lazy to fix the problem.
Share the .skp file so we can see what you’ve got.
There is a command you can type in the Ruby console that disables plugins altogether, but I doubt if that is what you want. However, until you clean out the junk, you are likely to encounter errors in the plugins you want to use, too.
