Issue with importing a viewport in Hybrid mode in Layout 2024
I just upgraded to sketchup 2024. Previously, i was using sketchup 2022.
I just tried to import a skp model(2022 version) in layout using the hybrid viewport.
In Hybrid:
The lines on the module is supposed to be white colour but changes to black only in Hybrid viewport. does not matter what colour i change it to it is still a black line.
How do i resolve this?
System Configuration:
Windows 10
32gb RAM
i9-11950H
Nvidia RTX a4000 GPU
Thanks in advance
Hi @Sharatb - A bug was introduced in the 2024 release where edge color assigned in SketchUp are not being passed to LayOut. This issue was actually caused by a change in SketchUp (exporting to pdf from SU will show the same issue) it just manifests itself more readily in LayOut.
We are aware of this and are working on a fix. The current only way to display the correct color is to use Raster render.
We are sorry for the inconvenience.
Trent
Thank you!!
Hi @trent ,how to use Raster render.
You select the rendering method for each SketchUp viewport with a popup menu in the SketchUp Model tray. For output, uncheck the Output Override in the Dcument Setup>Rendering dialog.
I know this is an older thread, but I am having a similar issue…
In SU and LO 2025, I bring in a viewport from SU that has colour and textures in it. When displaying in LO the following happens;
Vector – The view is correct to the nominated style from SU
Raster – The contents of the view port disappear (i.e. all white)
Hybrid – The contents are all monochrome.
I wish to use the hybrid style but, as it’s only black and white, it’s not giving me the desired effect. What have I done? Loosing considerable hair at this stage.
If you can share the file it’s possible to know better what is happening.
Sure. The SU file is 8.4mb and the LO file is 32.3mb. Is there a file size limit here?
So, wierd stuff is afoot… After saving, closing and rebooting, the issue has resolved itself.
Thanks again for the assistance.
I am experiencing the same issue in 2025 and seriously in 20+ years of using Sketchup & Layout I have never had so many issues with the software than in the last two releases.
I thought we would be getting better than facing an issue as silly as presentation of viewports.
This software was so much easier when it was simple!
Lets not make it difficult or frustrating and turn users away from using this great software package.
